THowe683's avatar
THowe683
Wifi Extender Setup - WRT1000v4
I am looking to use a WRT1000v4 as a wifi extender to my existing Netgear WNDR4500v3 wifi router.  I cannot seem to find instructions on how to set it up.  I did see a setting under Advanced / Advanc...
  • ElaineM's avatar
    ElaineM
    Jan 18, 2017
    Both should have wireless repeating in order to set it up completely.
    The only way to extend the signal is to connect the second router with an Ethernet cable from main router.
