BARTSBUTT58
Dec 21, 2020Aspirant
WIFI EXTENDER WN3000RPV3
hi there I recently whilst upgrading my firmware lost all firmware from my wifi extender how can I reinstall the firmware so I can use the extender.I have tried factory reset to no avail. when I plu...
Dec 21, 2020Guru - Experienced User
You can try recovering it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
- BARTSBUTT58Dec 21, 2020Aspirant
Hi there
I just tried to flash it but it is coming up that the firmware download is corrupted
- plemansDec 21, 2020Guru - Experienced User
what is telling you its corrupted?
If you're able to go through the extenders interface, then you don't need tftp.
So whats telling you this?
sorry for lack of info TFTP tells me after I try to upgrade firmware just sits there telling me failed
sorry it comes up with failed to resolve host address
