BARTSBUTT58
Dec 21, 2020Aspirant
WIFI EXTENDER WN3000RPV3
hi there I recently whilst upgrading my firmware lost all firmware from my wifi extender how can I reinstall the firmware so I can use the extender.I have tried factory reset to no avail. when I plu...
Dec 21, 2020Guru - Experienced User
You can try recovering it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
BARTSBUTT58
Hi there
I just tried to flash it but it is coming up that the firmware download is corrupted
