rs2022
Jan 02, 2022Tutor
Wifi Extender
I would like to extend the wifi connection in my garage and backyard. I have a 2-pack AX4200 Tri-Band Mesh Wifi 6 system wherein I have placed the ORBI router downstairs and the ORBI satellite upstai...
michaelkenward
Jan 03, 2022Guru - Experienced User
plemans wrote:
There is the RBS50Y that is outdoor rated. It can't be used in orbi mode to connect ....
It has that option here.
I use one in an office-to-house chain as a link between an Orbi router (AP mode) and an Orbi satellite.
But I have no idea what rs2022 means by AX4200 Tri-Band Mesh Wifi 6. That could be an Orb RBK75X bundle, a RAX4X or a CBT75X. So, while the text refers to Orbi devices, whether or not Orbi mode would work with this device isn't clear to me.
The RBS50Y doesn't work with the AX orbi solutions in Orbi mode. Only in extender mode.
If the OP doesn't have an Orbi AX system but a standard RAX router, then extender mode would still work.
IF they have an Orbi AC system then both extender and orbi modes would work.
