SoaringKite
Jan 12, 2021Follower
Wifi extenders N300 no longer recognizes password
Hello, I have 3 N300 Wifi extenders, and after an electrical outage due to a snow storm, none will connect with the router. I see the various extenders on my Mac, but when I try to connect to any...
Jan 12, 2021Guru - Experienced User
Hopefully you aren't daisy chaining n300 extenders.....
with that siad, a couple things to try.
1. make sure to go into your macs to forget the settings.
2. you can try factory resetting the router and the extenders
3. when you're setting up the extenders, are you using wps or using the installation assistant? I'd highly recommend the assistant.
