kpinisetti
Dec 05, 2023Aspirant
Wifi in a Metal Building
 HELP !! I have a 80x240 Metal horse barn half of it is riding arena and the other half is stalls. The middle of the barn is a lounge where my local internet companies fiber cable comes into. I have t...
Dec 05, 2023Guru - Experienced User
I'd put in a CAT6A STP lan cable from the host router and run it into this central lounge area then connect up a RBS or wireless AP that gets connected to the LAN cable:
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System 📡 ‌‌🛰️
Metal building will be a shield from outside signals thus cutting down or all together signals from outside signal sources. Not ideal for any wifi system.
- kpinisettiDec 05, 2023AspirantThe main cable comes into the lounge and there is an ethernet port in there that i run a cable from to the host router and the signal is transmitted from there - FURRYe38Dec 05, 2023Guru - Experienced UserAre you needing signal outside as well? Again this will be problematic from signal going from inside to outside. Or just with in the barn building? - kpinisettiDec 05, 2023Aspirantno i do not need signal outside just inside
