kpinisetti
Dec 05, 2023Aspirant
Wifi in a Metal Building
HELP !! I have a 80x240 Metal horse barn half of it is riding arena and the other half is stalls. The middle of the barn is a lounge where my local internet companies fiber cable comes into. I have t...
Dec 05, 2023Guru - Experienced User
Are you needing signal outside as well? Again this will be problematic from signal going from inside to outside. Or just with in the barn building?
kpinisetti
no i do not need signal outside just inside
- FURRYe38Dec 05, 2023Guru - Experienced User
Sounds like maybe some ethernet cabling out from the host router out to remote locations with in the building and then connect up wireless APs to the end points of the ethernet cabling locations should be looked into.
Host router> CAT6A STP cabling to 2-3 locations with in the building<>A wireless AP located at the far ends or corners of the building. Might look at NGs WAX series of APs.
