Jeiraon
Sep 20, 2019Aspirant
Wifi input with web authentification
Hello. I would like to have your advise to choose a device. I already looked into it but I am kind of lost. In brief, I am currently in a university residence with a free wifi network. But to conn...
- Sep 21, 2019
Basically you're looking for something like a travel router like the PR2000 that Netgear doesn't offer. There are other manufacturers that offer these type of products.
https://community.netgear.com/t5/General-WiFi-Routers-Non/WiFi-WAN/td-p/1772536
When you check with your univerisity IT department and if they allow it, they should be able to tell you if a standard router (and the settings to make it) will work or if you need something specialized.
Sep 20, 2019Guru - Experienced User
I would check with your university IT department. Many universities have rules/regulations in place for this. They might allow it but have certain devices they recommend or they might say don't do it as it creates more interference for their network.
Jeiraon
I didn't thing about that aspect and I see what you mean, I will also check with them.
Otherwise if it is not prohibited, I would like to know if a router can authenticate on a Wifi as input with a web authentication (and maybe which one)?
Thank you for your time.
Best regards.
- plemansSep 21, 2019Guru - Experienced User
