Geigs's avatar
Geigs
Wifi is becoming less Y and Fi. Suggestions appreciated
Hi all, I have a N90 WNDR4500 hooked to a Surfboard SB6121 and a WN3000RP with Comcast Blast Internet.  http://results.speedtest.comcast.net/result/1006783724.png   It used to be fast and coverage w...
  • netwrks's avatar
    netwrks
    Aug 25, 2015
    You could try factory resetting your router, and reconffigure. Or, it could be that the router is starting to fade away.. Extenders, although a good idea, lose about 50% throughput between the router and extender. If your extender can run in AP mode, then that could also be an option.
    Or, go for an AC router (not the R7500 or R8000) that has external antennaes, which in turn, could provide the wireless coverage you need in your environment.
