Mystified's avatar
Mystified
WiFi Lights Blinking Pattern
Been having WiFi Connect/Disconnect issues over the last few weeks. After recycling power, everything is fine for a random period of time in days. This happens on 2G and 5G.   Saved image, reset to...
  • Mystified's avatar
    Mystified
    Jan 21, 2024
    Sorry for the late reply. I wanted to wait and verify/confirm that it was indeed fixed.
    At this point, everything is fine, have not lost any WiFI connections, the lights are displaying the same as my other Netgear R6350 which is physically right next door.
    It seems it was the power brick; fortunately I had many other power bricks and managed to find one with the exact same electrical specs and checked the power connecter that goes into the router with my electronic caliper, the OD was .005 millimeters smaller, but fits tight and doesn't wiggle.
    Will get a new one this week.
