Trishy's avatar
Trishy
Wifi Mesh Extender AC1750
I have just installed this extender.  It would not connect automaticall to my router using the WPS method and subsequently I installed the Nighthawk app on my phone and set up that way.  I don't know though that it is working.  How do I tell?  And it appeared to connect at 2.4GHz and my router supports 5GHz.  How do I change and do I need to change?
  • michaelkenward's avatar
    michaelkenward
    Which extender?
    AC1750 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
    Look at the label on the device for the model number. Extenders are usually something like EX6XXX.
  • plemans's avatar
    Like michaelkenward says, what actual model do you have?
    Some are mesh devices and they don't broadcast a seperate ssid unless you disable "onessid" function.
