BIGPAUL09's avatar
BIGPAUL09
Follower
Sep 08, 2022
Wifi networks
Hi all, what I would like to ask is is there any routers that I can use to get a connection to my daughters wifi network who lives round the corner from me, I do remember having a router a long time ago that did this but can't remember which one, thanks in advance.
  • FURRYe38's avatar
    How far around the corner? Feet?
    A wifi bridge would be something that could work but if distances are too great then the unit wouldn't connect.
  • plemans's avatar
    FURRYe38 is asking the right questions.
    1. how far is it?
    2. do you have line of sight?
    3. what is between the 2 buildings?
    4. what did you use before? (gives us an idea of what worked)
