missouriupser
May 25, 2021Aspirant
Wifi not connecting to XR IPHONE
I have had the router installed since 2017 and haven't had much trouble but when my girls are home from college they complain that their Iphones will not work on wifi, shows connection but no service...
missouriupser
May 27, 2021Aspirant
I've checked firmare on the wifi router and it's up to date through the GENIE. I've follow a couple of instructions of resetting the router and the phones and then I tried resetting the phone settings and neither worked. So I'm at a loss!
May 27, 2021Guru - Experienced User
I am too because you didn't give me any additional info. Look back at my post and answer the questions. We need details to help
- missouriupserMay 27, 2021Aspirant
I'm Sorry but I have a NetGear N600 wifi Dual Band Router
Model number WNDR 3400
The N600 is in the middle of the ground level part of the house.
As far as the extenders I have the one on both ends of the house and then one upstairs.
I
The modem is an ARRIS Model TM1602A
- plemansMay 28, 2021Guru - Experienced User
And what extenders do you have?
I usually tell people to avoid multiple extenders. If you're needing more than 1 extender to cover a home, its better to move to an actual mesh system like netgear orbi or the nighthawk MK series. They're designed for multiple AP's.
Plus you're using a router that was manufactured 11 years ago and is a couple generations behind on technology. Its doesn't lead to great coverage/roaming/stability.
