missouriupser
May 25, 2021Aspirant
Wifi not connecting to XR IPHONE
I have had the router installed since 2017 and haven't had much trouble but when my girls are home from college they complain that their Iphones will not work on wifi, shows connection but no service...
missouriupser
May 27, 2021Aspirant
The modem is an ARRIS Model TM1602A
May 28, 2021Guru - Experienced User
And what extenders do you have?
I usually tell people to avoid multiple extenders. If you're needing more than 1 extender to cover a home, its better to move to an actual mesh system like netgear orbi or the nighthawk MK series. They're designed for multiple AP's.
Plus you're using a router that was manufactured 11 years ago and is a couple generations behind on technology. Its doesn't lead to great coverage/roaming/stability.
