Wolfpack1431
Nov 08, 2020Aspirant
Wifi not showing up on any device
So my wifi isn't showing up on any of my devices. I have my PC hardwired into the router and I have a internet connection but the WiFi is not showing up. I've tried restarting it several times and it ...
Nov 08, 2020Guru - Experienced User
Did you push your wifi on/off button? push and hold it for 2 seconds
- Wolfpack1431Nov 08, 2020AspirantYes I have and it's still not showing up
- plemansNov 09, 2020Guru - Experienced User
Did enable radio get unchecked?
Was the ssid broadcast disabled?
Or have you just tried a simply factory reset?
