robrajcs
Dec 04, 2020Aspirant
Wifi off after router restart or power outage Netgear R6400
After a router restart, or power outage my wifi goes off disabled. I must turn it on with the app or pushing the wifi button on the router I think normally it should be at its previous state after ...
Dec 04, 2020Guru - Experienced User
which firmware version are you on?
Hve you tried a factory reset and reinstall on it?
- robrajcsDec 04, 2020Aspirant
Firmware version: V1.0.1.62_1.0.4
I did not do factory reset.
- plemansDec 04, 2020Guru - Experienced User
I haven't heard of that issue with that specific firmware. maybe try re-installing the firmware and then a factory reset/reinstall. maybe something corrupt in the firmware.
