BHBUSAF
Sep 04, 2015Aspirant
Wifi over a 6000 sq ft house
I have been having issues with this for a while now and I'm at my wits' end. We live in a large house (2k sq ft basement, 1st floor, & 2nd floor). I currently have the N750 WiFi Router (model WNDR4...
- Sep 05, 2015
Personally, with the size of your home, I would be looking at moving up to a different class of router, R7000 and possibly EX7000, but that could be another discussion. The following covers off what you were looking for, information wise..
You will need to run at least CAT5e (not CAT5) cabling so that you can connect between your WNDR4300 and your WN604's LAN ports. As far as configuring the WN604's, (and depending what IP addresses are being used in your network right now) you could address the AP's as follows: (Assuming your router IP address is: 192.168.1.1) The easy setup:
AP1 - 192.168.1.253 NM 255.255.255.0 Gateway 192.168.1.1
AP2 - 192.168.1.254 NM 255.255.255.0 Gateway 192.168.1.1
I picked these IP address as they are at the far end of your DHCP Pool and should not cause a Duplicate IP Address issue. (Assumption is: You have not altered your DHCP Pool).
As for your whole home wireless network, you can use the same wifi SSID's for all the wireless but, ensure you select a wireless band channel 2.4ghz (1,6,11 assumption is, you are in North America) if you can and, higher band channels for 5ghz.
Use the same wireless passphrase for the WNDR4300 and WN604's . Make sure you use a STRONG wireless passphrase and use WPA2-PSK (AES) for wifi Security.
You can get a copy of acrylic for your laptop, or if you have an android phone, you can download WIFI Analyzer - this will allow to see what channels are being used around you, then you can select the wifi channels based on populated they are / aren't. For 2.4ghz, try and stay with 1,6,11).
As far as wirieless clients go, they decide how effectively they are going to roam. Ensure that WMM is enable on all your AP's, including your base router.
Here are you manuals: WN604 WNDR4300
If you have more questions, ask away.
netwrks
Sep 05, 2015Master
