3924router
Jun 10, 2024Follower
Wifi pool timer
How to connect 2.4ghz pool timer
Jun 10, 2024Guru - Experienced User
What router do you have?
What error are you running into?
What pool timer do you have?
Why do you think the Netgear support forums can help setup a pool timer and not the pool timer manufacturer?
