StanleyB
Mar 05, 2021Aspirant
wifi preset name and password for model R6120
Is there a good isecurity reason to change the preset name and password for the R6120 router wifi or is it safe to just leave them with the factory presets? My anit-virus complained about a "common ...
antinode
Mar 05, 2021Guru
> [...] My anit-virus complained about a "common name" for the wifi
"NETGEARxx" might be considered a "common name". Especially if you
have neighors with Netgear routers, and they don't change their SSIDs.
> [...] keeping the presets for the wifi was recommended in the setup.
I've never understood the reason for that recommendation. Perhaps
the idea was that the typical Netgear customer would choose some more
easily guessed passphrase than the original (two-word composite?) one.
But that wouldn't be a reason to keep the original (lame) SSID.
I choose a memorable/distinctive SSID, and a hard-to-guess
passphrase. And I try to ignore nonsensical advice.
