StanleyB
Mar 05, 2021Aspirant
wifi preset name and password for model R6120
Is there a good isecurity reason to change the preset name and password for the R6120 router wifi or is it safe to just leave them with the factory presets? My anit-virus complained about a "common ...
StanleyB
Thank you. So it's not easier for someone to hack into my wifi because of the default Netgear name? Also a related question - have any firmware updates reset the name and password to the factory presets?
I appreciate hearing from you so quickly today.
antinode
Mar 05, 2021Guru
> [...] So it's not easier for someone to hack into my wifi because of
> the default Netgear name? [...]
Hiding or changing an SSID does little for security. The passphrase
is what matters.
If someone knew a good way to break into Netgear routers, then an
SSID like "NETGEARxx" might make it easier to identify your router as a
Netgear router.
> [...] have any firmware updates reset the name and password to the
> factory presets?
Shouldn't happen, but if the settings get corrupted (by a firmware
update, or some other way), and the router notices it, then the router
might self-reset in an attempt to straighten itself out. One could
program both default and custom credentials into a device, and survive
such an event with little trouble.
