12Career
Sep 08, 2020Follower
WIFI Range Extender Models EX6100 and EXS6190
Hi, we've just had NBN installed today NSW Australia. The above models of our wifi range extenders now don't work. Can anyone tell me what I need to do to get them working NBN compatable? Thank y...
Lokerd
Dec 23, 2020Aspirant
I actually need the entire setup procedures. We moved house and I have not been able to locate the original instructions.
Dec 24, 2020Guru - Experienced User
find them here:
https://www.netgear.com/support/product/EX6100.aspx
make sure to select the correct version from the drop down box
the EXS6190 is made by netgear for telstra. so netgear doesn't have a manual. But it should be similar to how you install the ex6100
