Tmoore1981
Sep 20, 2023Aspirant
Wifi router help
Upgraded my wifi from 500 to 1 gig and my wifi speed is all over the place, one time its 500-600 other times 100-200. Getting consistent 600+ on ethernet. Was told my router was the issue ac2600 rx450...
Kitsap
Sep 20, 2023Master
Tmoore1981 wrote:
Upgraded my wifi from 500 to 1 gig and my wifi speed is all over the place, one time its 500-600 other times 100-200. Getting consistent 600+ on ethernet. Was told my router was the issue ac2600 rx450 so i bought a ax1800 wifi 6 wax204 and seems like it got worse on wifi. I was told the 6 should support gig internet. Not sure where im going wrong here if i have settings that aren’t right or what. On ethernet its consistent
Some background reading on your part will help you better understand Wi-Fi and throughput capacity.
Here is a link to a great reference document: https://www.duckware.com/tech/wifi-in-the-us.html
Recommend you start off with chapters 3 and 11.
When you are testing throughput capacity, recommend you use the installable stand alone Ookla application available in the play store. This program removes the web browser from being included in the data path.
CrimpOn
Sep 20, 2023Guru - Experienced User
As the referenced article points out, WiFi6 has a theoretical maximum bandwidth that is close to 1GB/sec, provided that the device being used to measure speed is capable of WiFi6 and 2x2 MIMO. and is very close to the router.
It would help to know:
- what device is being used to measure internet speed
- how far it is from the router
- Tmoore1981Sep 21, 2023AspirantIphone x and a 14. Within 5 feet. Both using speedtest app not via browser
