Tmoore1981
Sep 20, 2023Aspirant
Wifi router help
Upgraded my wifi from 500 to 1 gig and my wifi speed is all over the place, one time its 500-600 other times 100-200. Getting consistent 600+ on ethernet. Was told my router was the issue ac2600 rx450...
Sep 21, 2023Guru - Experienced User
What model router do you have? Is this a Orbi router or RAX series router?
Tmoore1981
Sep 21, 2023Aspirant
Both routers are listed in the original post
- KitsapSep 21, 2023Master
Tmoore1981 wrote:
Both routers are listed in the original postThere is no such router as a rx450 and the wax204 is a wired access point, not a router.
Please look at the label on the router for the model number.
What is the brand name and model number of the modem connected upstream between your router and the internet?
- Tmoore1981Sep 21, 2023AspirantI didn’t realize i mis typed its a r7450. I use spectrum internet so it’s whatever they supplied im not at home right now to look. I get 600-800 download at both the modem and via ethernet off the router/access point. Just seems like it shouldn’t be so inconsistent on wifi if it’s staying steady on Ethernet.
Tmoore1981 wrote:
I didn’t realize i mis typed its a r7450. I use spectrum internet so it’s whatever they supplied im not at home right now to look. I get 600-800 download at both the modem and via ethernet off the router/access point. Just seems like it shouldn’t be so inconsistent on wifi if it’s staying steady on Ethernet.Wi-Fi can vary depending on the radio frequency environment where you are located. Do you have relatively close by neighbors that also have Wi-Fi devices broadcasting?
If your two Wi-Fi devices, R7450 and WAX204 are within a few feet of each other, they can interfere. The interference also depends on what channels they are broadcasting on. The 2.4 GHz band has channel numbers as does the 5 GHz band. Do you have the SSIDs set the same on both devices?
If the Spectrum device is a combination modem/router, it can throw a third Wi-Fi device within range and complicate troubleshooting.
