Write2phil's avatar
Write2phil
Wifi Schdedule
Hi Everyone,
I installed my R6400 router (using the latest firmware version) as an access point.
Now, I would like to shutdown my wifi connexion (both 2,4 and 5 Ghz) between midnight and 7:00 am.
In the routeur's interface, I program both wifi to shutdown accordingly to an agenda depending of the day.
However, it does not work i.e. when the wifi should be down, I can still see it and access to it.
I join to this post an print screen of the wifi 2,4 Ghz configuration (it is the same for the 5 Ghz).
Could you please let me know where I am missing something.
Thanks for your help.
  • Common problem is time/date/time zone not properly configured.
    • Write2phil's avatar
      Write2phil
      Hello,
      Thanks for the quick answer and your help
      Indeed,time zone was not set up correctly in security->planning
      Regards
