Omegaman66's avatar
Omegaman66
Follower
Mar 17, 2022
Wifi security code for Model No. R6400-100NAS
Netgear AC1750 SMART WIFI ROUTER
802.11ac Dual Band Gigabits
  • plemans's avatar
    There's a support site with access to manuals, firmware, install guides, etc.
    Go to https://www.netgear.com/support/
    Type in your model number and from there it'll take you to the above.
    Its a great resource to start with.
  • michaelkenward's avatar
    michaelkenward
    Look at the label on the R6400. This has the default wifi SSID and "Passphrase".
    Maybe that is what you mean by "Wifi security code". That is not a label that appears in any Netgear manual.
