gchengznetg1
Dec 03, 2020Follower
WiFi speed is low
The WiFi speed is 300+300Mbps in the specification, But only get 90 Mbps after router. If directly connect to the modem, the speed is 215 Mbps. Is it router problem? Or other facts can cause this ...
- Dec 03, 2020
> [...] only get 90 Mbps after router. If directly connect to the
> modem, the speed is 215 Mbps. Is it router problem? [...]Perhaps "limitation" would be more accurate than "problem".
Different model, same limitation:https://community.netgear.com/t5/x/x/m-p/1711958
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the WNDR3300v2 Setup Manual. Read. Look for
"Technical Specifications" and "Interface Specifications".> [...] Or other facts can cause this problm? [...]
Other things _could_ cause such a problem, but the specifications of
the WNDR3300v2 would be enough.
> WiFi speed is lowIf you check, I'd guess that you'd find that your wired speed is
similarly limited.
antinode
Dec 03, 2020Guru
> WiFi speed is low
similarly limited.
