JesusHidalgo
Aug 03, 2020Tutor
Wifi Upload speed R6250 on 5Ghz very slow on AP mode
Hello, I have a Netgear R6250 for some time already, and it was working fine in the normal configuration ( I had it connected via Ethernet to the ISP router and using all the configuration from ...
- Aug 03, 2020I mean more a reset of the R6250.
How I'd do it? Install version 1.0.4.42 firmware to the R6250 over a hardwired connection, factory reset it, and then reinstall it.
Aug 03, 2020Guru - Experienced User
In ap mode, the primary router is what should be setting the speeds. Any qos settings on it?
Have you tried a factory reset and reinstall on it?
What router is it connecting to?
What firmware is on the R6250?
JesusHidalgo
Aug 03, 2020Tutor
Hello plemans, and thank you for your quick answer.
With regards to your questions:
- The router from the ISP is:
Mitrastar HGU GPT-2541GNAC
I have tried disabling the QoS and the result is the same (But would it be normal to affect only the 5GHz Wifi connection?)
- The RS6250 is on Firmware V1.0.4.38_10.1.30
- I have done a Factory Reset of the ISP router some time ago due to another problem, but the behaviour has not changed.
Thank you
- plemansAug 03, 2020Guru - Experienced UserI mean more a reset of the R6250.
How I'd do it? Install version 1.0.4.42 firmware to the R6250 over a hardwired connection, factory reset it, and then reinstall it.- JesusHidalgoAug 03, 2020Tutor
Hello plemans,
Thank you very much. I have installed the latest Firmware and perform a factory reset and now it seems to be working fine.
I am not sure which of the two actions solved the issue, but it is done.
Thanks for your help!
- plemansAug 04, 2020Guru - Experienced User
Glad to hear you got it working!
