JesusHidalgo
Aug 03, 2020Tutor
Wifi Upload speed R6250 on 5Ghz very slow on AP mode
Hello, I have a Netgear R6250 for some time already, and it was working fine in the normal configuration ( I had it connected via Ethernet to the ISP router and using all the configuration from ...
- Aug 03, 2020I mean more a reset of the R6250.
How I'd do it? Install version 1.0.4.42 firmware to the R6250 over a hardwired connection, factory reset it, and then reinstall it.
JesusHidalgo
Aug 03, 2020Tutor
Hello plemans, and thank you for your quick answer.
With regards to your questions:
- The router from the ISP is:
Mitrastar HGU GPT-2541GNAC
I have tried disabling the QoS and the result is the same (But would it be normal to affect only the 5GHz Wifi connection?)
- The RS6250 is on Firmware V1.0.4.38_10.1.30
- I have done a Factory Reset of the ISP router some time ago due to another problem, but the behaviour has not changed.
Thank you
Aug 03, 2020Guru - Experienced User
- JesusHidalgoAug 03, 2020Tutor
Hello plemans,
Thank you very much. I have installed the latest Firmware and perform a factory reset and now it seems to be working fine.
I am not sure which of the two actions solved the issue, but it is done.
Thanks for your help!
- plemansAug 04, 2020Guru - Experienced User
Glad to hear you got it working!
