mayofred
Mar 14, 2022Follower
Will my router support 1gig speed;
Will this router support 1 gigabyte of internet speed?
IF your referring to the WNDR4500..maybe, however it's old enough, he may not have the HW NAT acceleration support or cut-thru needed for ISPs with 1Gb Down and UP speed support.
Something to review and you could check on your own and see:
I would look at a tested review of the device from when it was released (11 years ago).
https://www.smallnetbuilder.com/wireless/wireless-reviews/31621-netgear-wndr4500-retest
That'll give you realistic expectations for that device.
If you're getting gigabit speeds, an upgraded router would be beneficial to utilize your speeds.
