bjkaufman
Aug 08, 2021Aspirant
Will the Netgear EX6400 work with the T-mobile NOK 5G21 Gateway Internet device
Will the Netgear EX6400 work with the T-mobile NOK 5G21 Gateway Internet device. If so, how would I hook it up? Does it have to go through a router? I do have a Linksys EA6350 router.
Aug 08, 2021Guru - Experienced User
Have you tried it?
You could try installing it using the installation assistant
