Ryan_M
Nov 02, 2021Aspirant
Will this work
I have a CM2000 and another netgear managed switch. Can’t get to the switch right now to get the model number. But it is an 8 port managed switch with 4 POE ports and 4 nonPOE. What I’m trying to d...
Nov 03, 2021Guru - Experienced User
Some of the higher end switches have nat/DHCP built in. Tough to know without a model number.
But if it doesn't, then you can't go that route.
If it does, you can use the switch for its routing capabilities and put the router in access point mode.
Ryan_M
Nov 03, 2021Aspirant
Update here: model for the switch is GS108PE-300NAS
- plemansNov 03, 2021Guru - Experienced User
I don't believe that switch has the capability from what I could tell going through its manual.
You might get better feedback in the switches forum.
https://community.netgear.com/t5/Switches/ct-p/business-switches
