ydlazkov's avatar
May 07, 2019
Will wifi extender work with RBR40 mesh?
I got RBR40 + 1 satellite setup in my house. But I think need a wifi extender to boost the wifi connectivity and speed at the area farthest from the mesh. From what I see to the videos and instructio...
  • plemans's avatar
    May 07, 2019
    orbi uses the sync button as a wps button.
    With that being said, I wouldn't use an extender with orbi. it'll create a seperate ssid as well as orbi tries to dynamically move devices between devices/radios. An extender will add interference, a seperate ssid (half the point of orbi), and potentially drop connection because of orbi moving it around.  It'll work but I'd highly recommend buying a seperate satellite for the orbi so you keep your seamless integration, seamless roaming, and wireless backhaul.
