caisson1
Feb 11, 2024Aspirant
Windows 10 does not recognize USB Flash drive From Nighthawk r8000
The USB is a Sandisk Ultra USB 3.0 Flash Drive, 512GB. Windows 10 File Explorer does not recognize the drive from the router's 2.0 or 3.0 port. The R8000 Firmware Version is the latest: V1.0.4.84_10...
- Feb 11, 2024
Thanks for the replies. I found a solution.
- Select Start > Run and enter \\readyshare in the dialog box.
Click OK. - Right click the drive and select Map Network Drive
michaelkenward
Feb 11, 2024Guru - Experienced User
microchip8 wrote:
You need to enable SMB1 in Windows.
Here's what to do.
Solved: ALL Netgear USB Drive Mapping Issues ReadyShareCo... - NETGEAR Communities
caisson1
