SerratiaMarcens
Dec 29, 2016Aspirant
Windows 10 laptop causes WNDR4500v3 to crash/restart every couple of minutes
I've been using a WNDR4500v3 (current firmware is 1.0.0.32) for over a year with no issues. Our cellphones, Ipads, apple TV, a 2007 iMac, and two laptops running Windows 8.1 all work fine. I just bou...
- Jan 03, 2017
For the benefit of others who are reading this, there's a beta fw that may resolve this issue.
Feel free to send me a PM should you have the same concern with WNDR4500v3 only.
loufromfwb
Aug 21, 2017Guide
COME ON NETGEAR!!---There's got to be a solution to this router constantly rebooting! I've tried everything in this discussion, and then some---but NOTHING works. It's obviously a conflict between the Killer 1535 card and this router's firmware---Is there nothing to do but replace with another product that is NOT a NetGear product?---Has anyone here found the solution? Did the proposed fix from Elaine work?
