Hank4's avatar
Hank4
Windows 7 not picking up IP address on WNDR3400 ethernet port
I have just replaced a WNDR3400v3 with a new unit (same model) due to a failure of the old unit. The old unit worked very well with both WinXP (SP3) and Win7 (SP1). My system is a dual-boot system, s...
  • Retired_Member's avatar
    Retired_Member
    Aug 24, 2016
    icon.pngDelete all connections and then reconnect and choose home network
