jj8279
Feb 27, 2023Initiate
WINDR4500 V2
Hi. I have an older WINDR4500V2 router, primarily used as a secondary router for my wireseless security cameras. Is there any way to remotely login to this router? The nighthawk app claims the rou...
Feb 27, 2023Guru - Experienced User
is it setup in router mode or access point mode?
(if its a secondary router, it should be in access point mode)
What I usually do is remote into a computer on my network and use that to access the ip address of the router. Tends to be the fastest
jj8279
I'm not 100% sure and at work at the moment but I think router mode. I will definitely check when I get home.
Perfect. Thank You!
