Dbehl
Jan 16, 2023Follower
Wired and Wireless AP - WNDR3800
I want to set up my WNDR3800 as a Acess Point. But I want it to support both Wireleess as well as wired. I get it working so computers connecting both wired and wirelessly to get the same IP addres...
michaelkenward
Jan 17, 2023Guru - Experienced User
How do I change my NETGEAR router to AP mode? | Answer | NETGEAR Support
That is how AP mode works.
What is the IP address for the device so I can access it and change settings.
A couple of ways, look at the list of items attached to your main router, That should have an IP address that you can connect to with a browser.
You could also look at the IP address of the AP's WiFi source.
If you are using a Windows PC, the desktop genie is good for this task.
genie | Product | Support | NETGEAR
Look at the "Map".
