shinsangeun
Dec 27, 2020Aspirant
Wired Backhaul is not working since some points(RBR20+2 of RBS20)
I have used RBR20 and 2 of RBS20 and I set up wired backhaul and had no issue at all. However, since about 2-3 weeks ago, internetet was not working and I noticed that one of satellite's color becam...
Dec 27, 2020Guru - Experienced User
What switch do you have it connected to?
If you direct wire the satellite to the router, does it work?
What modem/gateway do you have?
What firmware is on the router? And the satellites?
- shinsangeunDec 27, 2020Aspirant
I am using D-Link unmanaged switch.
I didn't test direct wire the satellite to the router.
I am using Motorola cable modem provided by Spectrum.
Firmware version is 2.5.1.16 which is the lastest one as of now.
Again, it had been working without any issue, but suddenly happened.
- plemansDec 28, 2020Guru - Experienced User
shinsangeun wrote:I am using D-Link unmanaged switch.---which one?
I didn't test direct wire the satellite to the router.---try this to ensure its not a switch issue.
I am using Motorola cable modem provided by Spectrum.---which one?
Firmware version is 2.5.1.16 which is the lastest one as of now.---its not actually.
https://www.netgear.com/support/product/RBS20.aspx#download
https://www.netgear.com/support/product/RBr20.aspx#download
make sure to update the satellites first.
Again, it had been working without any issue, but suddenly happened.---so check things like cables, switches that it potentially could be.
