shinsangeun
Dec 27, 2020Aspirant
Wired Backhaul is not working since some points(RBR20+2 of RBS20)
I have used RBR20 and 2 of RBS20 and I set up wired backhaul and had no issue at all. However, since about 2-3 weeks ago, internetet was not working and I noticed that one of satellite's color becam...
shinsangeun
I am using D-Link unmanaged switch.
I didn't test direct wire the satellite to the router.
I am using Motorola cable modem provided by Spectrum.
Firmware version is 2.5.1.16 which is the lastest one as of now.
Again, it had been working without any issue, but suddenly happened.
Dec 28, 2020Guru - Experienced User
shinsangeun wrote:I am using D-Link unmanaged switch.---which one?
I didn't test direct wire the satellite to the router.---try this to ensure its not a switch issue.
I am using Motorola cable modem provided by Spectrum.---which one?
Firmware version is 2.5.1.16 which is the lastest one as of now.---its not actually.
https://www.netgear.com/support/product/RBS20.aspx#download
https://www.netgear.com/support/product/RBr20.aspx#download
make sure to update the satellites first.
Again, it had been working without any issue, but suddenly happened.---so check things like cables, switches that it potentially could be.
