gailouise's avatar
gailouise
Wired connection not an option for firmware fix
"WNR2000v5 Firmware Version 1.0.0.42" suggests a wired connection be used for firmware upgrade.  I live where wireless is my only option. Shall I go ahead anyway?
  • gailouise's avatar
    gailouise
    Aug 07, 2017
    antinode:
    Thank you.  Yes, I do have an Ethernet cable connecting my desktop computer to the router. I did not know that this was considered a "wired connection".
    Thanks for educating me!
