gailouise
Aug 02, 2017Aspirant
Wired connection not an option for firmware fix
"WNR2000v5 Firmware Version 1.0.0.42" suggests a wired connection be used for firmware upgrade. I live where wireless is my only option. Shall I go ahead anyway?
- Aug 07, 2017
antinode:
Thank you. Yes, I do have an Ethernet cable connecting my desktop computer to the router. I did not know that this was considered a "wired connection".
Thanks for educating me!
ElaineM
Aug 03, 2017NETGEAR Employee Retired
Welcome to the community, gailouise
It's highly recommended that you use wired connection when uploading a firmware to the router.
Wireless connection may corrupt the firmware of the router if ever you lose wireless connection.
michaelkenward
Aug 03, 2017Guru - Experienced User
A wired connection really is the best idea, but a lot of people have successfully flashed over wifi.
Too help you to reach a decision, check what the release notes say about the new firmware. Some updates are there to fix security issues. Some people think it essential to fix even the most theoretical security holes.
