gailouise
Aug 02, 2017Aspirant
Wired connection not an option for firmware fix
"WNR2000v5 Firmware Version 1.0.0.42" suggests a wired connection be used for firmware upgrade. I live where wireless is my only option. Shall I go ahead anyway?
- Aug 07, 2017
antinode:
Thank you. Yes, I do have an Ethernet cable connecting my desktop computer to the router. I did not know that this was considered a "wired connection".
Thanks for educating me!
antinode
Aug 04, 2017Guru
Are you saying that you do not have any computer with an Ethernet
port which you can connect to the router?
You don't need a wired connection to the Internet. The firmware
upload may be more reliable if there's a wired connection between the
computer with the Web browser (and the firmware kit file) and the
router.
- gailouiseAug 07, 2017Aspirant
antinode:
