marianitten
May 21, 2019Initiate
Wired Speed cut in half
Hi. I've noticed that my router cut wired speed to half when I check it using speedtest.net. If I connect my PC directly to the modem(the same cable I use to the router) I'm getting:
20MB Dow...
- May 21, 2019
1. What is the firmware on the R6400?
2. modem and firmware?
3. Are you testing over wireless or hardwired? (I know you have to be hardwired to test the modem but I'm just making sure)
4. Are all devices getting this speed? Those devices?
May 21, 2019Guru - Experienced User
- marianittenMay 21, 2019Initiate
Hi!
Wasn't smart enough to think about trying with another devices. I got 20MB over wifi with my phones(s7 and s8+) so I reliazed that it was my laptop.
It seems that some DELL inspiron have issues with some app calle smartByte.
Installed latest version and it's giving me 20MB :)
Thanks!
- plemansMay 22, 2019Guru - Experienced User
glad to hear that you got it fixed! good work on finding the problem with you Dell!
