marianitten's avatar
marianitten
Initiate
May 21, 2019
Wired Speed cut in half
Hi. I've noticed that my router cut wired speed to half when I check it using speedtest.net. If I connect my PC directly to the modem(the same cable I use to the router) I'm getting:   20MB Dow...
  • plemans's avatar
    May 21, 2019
    1. What is the firmware on the R6400?
    2. modem and firmware?
    3. Are you testing over wireless or hardwired? (I know you have to be hardwired to test the modem but I'm just making sure)
    4. Are all devices getting this speed? Those devices?
