Dhawal's avatar
Dhawal
Wired speeds over 200 Mbps, Wired speed only 1 Mbps
I am using Spectrum and my Wired speeds are consistently showing up as 200 Mbps. but the Wifi speeds are always around 1 Mbps. The details from admin portal are below.
Hardware VersionC278T00-01
Firmware VersionV2.02.18
Cable Modem Serial Number3KW2537Y010EF
CM CertificateInstalled
  • plemans's avatar
    Have you tried changing channels that the 2.4ghz broadcasts on? Maybe you have interference
    • Dhawal's avatar
      Dhawal
      Tried changing the channel. Doesnt help much
      • plemans's avatar
        How about a factory reset and reinstall?
        What device are you testing on?
        have you tried other devices?
