prakaz
May 26, 2016Aspirant
Wireless and Guest network settings page are blank
I noticed that I am no longer able to see my wireless and "Guest network" settings. The pages are almost blank. Please check these screenshots: ==================================== ...
- May 27, 2016
Hello prakaz
Welcome to the community!
Another option you may do is to reflash the firmware of the router.
Meaning, download the firmware once again and upload it again on the router.
After firmware reflash, reset the router by using a paperclip for 10 seconds.
Once done, reconfigure the router manually and see if you'll be able to see the options.
ElaineM
May 27, 2016NETGEAR Employee Retired
Hello prakaz
- prakazMay 27, 2016Aspirant
Hello ElaineM
Thanks for reply. That worked!! :D
For anyone else having this problem, here is the instructions on how to downgrade the firmware: http://kb.netgear.com/app/answers/detail/a_id/28025
But please remember, you will have re-setup the internet from the start after the firmware has been reset. As in, do not use previously saved settings. It will not work.
Cheers!
