Habibulalam
Jun 10, 2016Tutor
Wireless distribution system
netgear R6220 ac1200 router are support Wireless distribution system(WDS) or not, if it support WDS, how to set-up My New router is netgear R6220 ac1200 and old router is Tenda F303, so how to set ...
- Jun 13, 2016
Thanks for your great respose. May i get details WAN Medium. Also how to disable the firewall/NAT functions on the Tenda. I want to just connect both router "Netgear R6220" and "Tenda F303" without any wire by how any how. i'll be grateful to you if you will help to me by instructing to connect both router.
Thanks again.
Retired_Member
Jun 10, 2016What does the Manual say?
