Habibulalam
Jun 10, 2016Tutor
Wireless distribution system
netgear R6220 ac1200 router are support Wireless distribution system(WDS) or not, if it support WDS, how to set-up My New router is netgear R6220 ac1200 and old router is Tenda F303, so how to set ...
- Jun 13, 2016
Thanks for your great respose. May i get details WAN Medium. Also how to disable the firewall/NAT functions on the Tenda. I want to just connect both router "Netgear R6220" and "Tenda F303" without any wire by how any how. i'll be grateful to you if you will help to me by instructing to connect both router.
Thanks again.
Habibulalam
Jun 11, 2016Tutor
I want to connect Tenda F303 with Netgear R6220 wirlessly. how to connect them without wire?
- TheEtherJun 11, 2016Guru
I'm pretty sure the R6220 does not support WDS. Even if it did, you wouldn't want to use it because WDS support on Netgear routers is very poor.
It looks like you can set the WAN Medium Type to wireless on the Tenda. This will allow you to connect to the R6220's Wi-Fi network. The only downside is that the Tenda will behave as a router, not as a bridge. Unless you can disable the firewall/NAT functions on the Tenda, devices connected to the R6220 won't be able to communicate with devices connected to the Tenda.
- HabibulalamJun 13, 2016Tutor
Thanks again.
