Habibulalam
Jun 10, 2016Tutor
Wireless distribution system
netgear R6220 ac1200 router are support Wireless distribution system(WDS) or not, if it support WDS, how to set-up My New router is netgear R6220 ac1200 and old router is Tenda F303, so how to set ...
- Jun 13, 2016
Thanks for your great respose. May i get details WAN Medium. Also how to disable the firewall/NAT functions on the Tenda. I want to just connect both router "Netgear R6220" and "Tenda F303" without any wire by how any how. i'll be grateful to you if you will help to me by instructing to connect both router.
Thanks again.
TheEther
Jun 13, 2016Guru
I suggest that you look online for the Tenda manual. Alternatively, just look around on the router. It shouldn't take you too long to find the appropriate settings.
