deltadelta
Nov 16, 2020Aspirant
Wireless light is out + 5 GHz light is blue
We have Cox Communications internet at 150 mbps download max Preferred speed and 2 machines using it. One is a desktop PC that is ethernet connected to the router, and gets the full 150 mbps speed. A...
Nov 16, 2020Guru - Experienced User
deltadelta wrote:We have Cox Communications internet at 150 mbps download max Preferred speed and 2 machines using it. One is a desktop PC that is ethernet connected to the router, and gets the full 150 mbps speed. A mere 15 feet away is my HP laptop (only 2 years old) connected wirelessly. The laptop PC struggles to get more than 40 mpbs download and more than 5 mpbs upload. My netgear router was purchased in 2015.
Question #1: The light for the 'wireless' button is always off. Does this impact the wireless output?
Question #2: The light for 5 GHz is blue - all other lights are green. Does this mean 5 GHz is not working?
Would appreciate any feedback on the issue and how to resolve same.
THanks!
The wireless light if off, usually means the wireless is disabled.
But then you put the 5ghz light is blue, which means its broadcasting.
The manual goes over these.
https://www.netgear.com/support/product/WNDR3700v4.aspx
Is your pc dual band or single band? meaning does it have a 5ghz wireless chip in it? reason why is 2.4ghz is slow.
deltadelta
Thanks for the response. I need further clarification on the processor speed issue you reference. See below:
1) The HP laptop that is reflecting low mpbs rates (40) has an Intel dual core processor with speed range of 2.5 to 3.1 GHz. I access the internet wirelessly from the router.
2) THe HP desktop in the same room that is getting 150mpbs is connected to the router with an ethernet cable. This machine has an intel processor at a set rate of 3.1 GHz.
If they both have an intel processor with similar GHz rates, their speed test GHz rates should be relatively the same. They're not. The desktop is 4x faster.
It seems that something else is adversely impacting the laptop low mpbs speed.
Your thoughts?
- wcalifasNov 17, 2020Prodigy
If its a wndr3700 the blue light means the 5ghz is on, the 2.4 ghz will have a green light. If they're both on it means its sending wifi. You'll get the higher speeds on the 5ghz but it has a shorter range, while the 2.4 ghz has longer range and slower speed. No router will give you maximum speed over wireless. Wired you'll get maximum speeds.
- plemansNov 17, 2020Guru - Experienced User
deltadelta wrote:Thanks for the response. I need further clarification on the processor speed issue you reference. See below:
Your thoughts?
I wasn't meaning the cpu in your computer. The wireless chip in it is different than the pc processor. A device with only a 2.4ghz wireless chip won't hit the same wireless speeds because 5ghz is faster.
- wcalifasNov 17, 2020ProdigyThe difference is that wireless will not give you the same speed as when you have it wired. That goes for all routers out there. Wired is the way if you want full speeds.
- deltadeltaNov 18, 2020Aspirant
Thank you for taking the time to add some perspective to the issue. Since i purchased the HP laptop 4/2018, I'm surprised the specs that came with it don't detail the important wireless speed issue you mention. My wireless connectivity is 802.11b/g/n (1x1) and the network interface is an integrated 10/100 base-T Ethernet LAN.
Is there anything in my settings that can tweek the the wireless hardware to move up to the 5 ghz I'm looking for?
- plemansNov 18, 2020Guru - Experienced User
You potentially can swap out the wireless card for a dual band one.
some laptops its pretty easy on.
And some have issues with compatibility.
